Hikvision NVR DS-7732NI- I4/16P/KB
Matt-h
Hello,
I’m looking at wiring multiple alarm inputs direct from the NVR using luminite sensors. Using the Hikvision NVR DS-7732NI- I4/16P/KB. I have wired into the alarm inputs and connected the ground to the ground screw. Is this the correct way as the ground isn’t built into the terminals?
Also I assume when you have multiple sensors you just connect each one to its own input and all grounds go to the same terminal for the inputs.
