IP camera and mount
santi_cazorla
Hi there,
quick question.. is the mount: DS-1294ZJ compatible with the camera: DS-2CD2385G1-I.
I need a mount that has a small surface area (needs to be mounted onto a flat porch sofit which is very narrow - too narrow for the camera to mount directly)
No, the only compatible wall bracket for the 2385G1 turret is the DS-1273ZJ-140 Wall Bracket
We don't usually recommend turret cameras for porches as they are not designed for close-range recording, the turrets have 30m IR LEDs which can whiteout/overexpose objects that come very close to the camera, for porch cameras we usually recommend Mini Domes like the DS-2CD2545FWD-I as these have 10m IR which is much better for covering those short distances.
