Latest firmware for my IP Cameras Please
faranyaseen
Hi guys Can someone please recommend if i have the latest firmware for my cameras...
DS-2CD4A26FWD-IZS/P - V5.4.7 BUILD 180309
DS-2DE4A225IW-DE - V5.5.71 BUILD 180725
DS-2CD2347G1-LU - V5.6.5 BUILD 200316
DS-2CD2142FWD-I - V5.5.82 BUILD 190909
Please share link if posible for each firmware.
Many Thanks
Rather than ask someone to do it for you....
Go to DOWNLOAD EU PORTAL
If you look at the bottom of the page there's an Excel spreadsheet that tells you which camera models are which platform. Just use the search icon (magnifying glass) in the top right corner of the sheet and type in your model number to see which column and therefore firmware platform that model uses. As an example you'll find:
- the DS-2CD2347G1-LU is G1.
- the DS-2CD2142FWD-I is R6.
Once you know what platform your cameras are on you can just check back to the appropriate folders occasionally to check if there are any new versions available . One thing to note is that the UK portal and EU portal sometimes have newer versions than one another.
You can access the EU portal at hikvisioneurope.com/portal (then Portal > Technical Materials > 00 Network Camera > 00 Product Firmware) or the UK portal at hikvisioneurope.com/uk/portal (then Portal > Product Firmware > Front Ends > IP Camera). There is also a link to jump between the EU and UK pages from whichever you are in.
