CQR-View
- Messages
- 77
- Points
- 18
Is there any particular reason why it is not normally suggested the NVR be Factory Reset after applying an upgraded firmware?
Correspondences I have had with Hikvision Support will on almost every occassion suggest the NVR should be Reset.
I might be the odd one out here, but it does make perfect sense as far as i'm concerned:
- a) Factory Reset after a new firmware is installed would ensure the new firmware functions as the Manufacturer intended
- b) Eliminate/Remove any little inconsistancies which may exist from settings made long ago
- c) By reconfiguring the parameters & settings you can be certain they will all work again & identify any new/added features associated
Further to this, it should be a snowball effect with mobile device apps & pc client software. Delete the device & add it again.
I have practiced this method for some time now & rarely have any issues afterwards ............................... just seems logical
(no offence) In general a FW update/upgrade (for any device/component/system for that matter) should never require you to reset/revert to default factory settings unless explicitly stated upfront it will brick you're component otherwise. Hikvision is a company that has its primary focus on (large/enterprise) businesses beside consumers. You can't expect customers with a large Hikvision implementation (let's say 50+ camera's and large NVR setups to factory-reset each individual component whenever a new FW is released. I wouldn't think twice to switch to another vendor if that would indeed be the official advised approach on performing FW updates.
